hello all, call me stupid but i think i keep reading that people can decrypt and then burn with dvd decrypter. i know how to rip and save to the hard drive. i also know how to recall the video_ts and burn to dvd-r. is there a way to do this all at once?? i mean tell dvd decrypter to rip and burn in one function?? thanks----dave![]()
DVD Shrink works great.
You can BACKUP the entire dvd or just the parts you want.
You also have the choice to either backup to your hard drive OR backup to immediatly reburn to DVDR. -
Hey DVDDave,
in dvddecrypter go Mode/ISO/Read , this will create an image file .ISO
to burn go Mode/ISO/Write select the ISO file and it will burn it for you
only good for DVD5 , ie single layer DVD's -
As stated above there are two ways people burn DVD Videos with DVD Decrypter.
1) Backing up a DVD5 (single layer) disc
a. choose "mode | iso - read" and rip an ISO image file to the HD
b. choose "mode | iso - write" select the image file, insert blank media and burn
2) To burn a generated VIDEO_TS/AUDIO_TS folder
a. d/load and install imgtools classic
b. make an iso image file using imgtools
c. see above ("mode | iso - write")
So a 100% freeware solution for backups is dvd decrypter, dvd shrink and imgtools. Between these three programs you're pretty much set. The reason a lot of people here recommend imgtools/dvd decrypter is because it produces a more compatiable DVD image then burning with say nero. A lot of people use nero and have no problems, but IMHO it's worth about as much as a bag of warm cow dung.
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 12:42 -
DVD Decrypter
By Beaker14 in forum Newbie / General discussionsReplies: 17Last Post: 26th Oct 2007, 22:39 -
Help with DVD Decrypter
By Me-Hostage in forum DVD RippingReplies: 10Last Post: 20th Aug 2007, 08:12 -
Burn audio CD with ImgBurn and DVD Decrypter - not enough space
By theWallflower in forum AudioReplies: 11Last Post: 7th Aug 2007, 15:21 -
burn with dvd decrypter but copy by nero ?
By GINZY in forum DVD RippingReplies: 2Last Post: 6th May 2007, 07:05
