i was wonder if i could put 2 svcd disk on 1 dvdr i dont care about the format as long as i can play it in my dvd player and all that
ScootZilla
https://www.videohelp.com/guides.php?howtoselect=3;29#3;29 (no video reencoding)
The easiest way is in the guides to the left. You can 'patch' the header to make your authoring program think the 480x480 SVCD video is actually 352x480. Then just re-encode the audio from 44.1 -> 48 and author as normal. This works pretty well.
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
Sticky upate? When will Dual Layer DVDr disk be available
By JoeBolden in forum FeedbackReplies: 1Last Post: 11th Jun 2008, 03:54 -
dvd9 to one disk dvdr
By mordor in forum DVD RippingReplies: 6Last Post: 27th Mar 2008, 01:44 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19
