Hello Folks,
I was wondering if there is a MPEG2 editor that I can copy/paste a single frame manually? Mostly I have several videos that have a few corrupted frames on the original tapes. It's not dropped frames in the capture card. So I figure that maybe I could go to the frame before, copy and then paste the good frame onto the bad frame. Is there anything capable?
Thanks...BTW...Cool Site![]()
BobbyDing
My suspicion is that you "can't" atlhough I've never tried. If your source were DV, there would be no problem. However, MPEG is compressed, so that you have a "real" frame (I-frame) every half second or 15 frames. Just from what I've read on this site, MPEG editing (even simple cuts and joins) is fraught with difficulties and probably should be avoided. Alternatively, you could convert to DV or Huffy, do your frame editing, and then reconvert to MPEG but you would lose quality.
If I'm wrong, I'd also be interested.
wwaag
Replace every 15th frame with 14th frame
By NBninja8 in forum RestorationReplies: 43Last Post: 23rd Aug 2011, 03:49 -
Replace first frame of WMV file?
By HiTechHiTouch in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2011, 21:18 -
How to calculate single frame duration
By 8day in forum Newbie / General discussionsReplies: 4Last Post: 5th Dec 2010, 10:49 -
Unwanted Single frame problem
By Redcliffe in forum Capturing and VCRReplies: 5Last Post: 20th Jan 2009, 16:15 -
Adding Text to a Single Frame
By dogberry578 in forum Newbie / General discussionsReplies: 5Last Post: 8th Jan 2008, 16:03
