I have been tryiing to get Split Me to split an avi file. The problem is that Split Me needs to have Mencoder in usr/local/bin. When I try to move mencoder to the bin folder, it gives me an error message "bin cannot be modified. In other words, it won't let me move or even copy and paste the program to the bin folder. I tried logging in as root, and that didn't help, because none of my programs are available, or on my desktop, when I am in as root. So my question is how in the world do I get mencoder to usr/local/bin, and where exactly are all these folders. Please bare with me, as I really haven't had my mac that long. By the way I am using OS X 10.2.8. Thx.
I have this back form my 10.2 days. Should work for you. Essentially you cant just go in and add folders to that directory directly.
Code:To install Mencoder, do the following. Download this file: http://heanet.dl.sourceforge.net/sourceforge/mplayerosx/stablebinaries.sit Once is it decompressed, open the terminal and change to the folder you downloaded to. If it goes to your desktop, it would be: cd ~/desktop/stablebinaries once in that directory, type: sudo cp mencoder /usr/local/bin/ -then- sudo cp mencoder /usr/bin/ You be asked for your password. Then type: rehash Mencoder should be ready for ya.
Edit .mkv file (split/join) - nothing works "properly"!!!
By The.King in forum EditingReplies: 19Last Post: 11th May 2013, 06:23 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
Quality problem "caused" during "deinterlacing" ?
By Hombre_86 in forum DVD RippingReplies: 26Last Post: 25th May 2010, 21:28 -
Auto-split 10 hr capture in 3 min chunks "on the fly"
By atvmxr in forum Capturing and VCRReplies: 2Last Post: 22nd Apr 2008, 09:48
