Hi at all, I've seen topic about avi to 3gp conversion but... I want to convert 3gp video to AVI or any other video format. Anyone can tell me how?
Bets regards.
8)
3gp is the standard used by Nokia 6600 to save videoclip. Otherwise it's know also how 3gpp but the question remains the same: how can I convert 3gp or 3gpp in any other video format?
8) -
Pardon my ignorance. :P I'm afraid I can't help you. It wouldn't hurt to open them with G-spot still. Maybe there's a standard video stream that's only in the 3gp container. How are these files created? Maybe whatever program used can extract or demultiplex the streams somehow. Just a guess.
3gp is a MPEG 4 dialect but uses a non-open codec owned by Ericsson and a company called VoiceAge. The videos need a proprietary player to play back the recordings and there's a nasty looking patent/license thing that you find if you go looking to install the codec for translation. This is the same thing you run into when you record voice stuff on the Nokia phones as well, they are coded as AMR files which, again, are proprietary and need special players. I guess the idea is that these are the "standard" codecs in the MMS world based on agreements made in the 3GPP consortium.I think,therefore i am a hamster.
Not sure if you found the answer in the meantime but Xilisoft 3GP Video
Converter works both ways (avi---> 3gp and 3gp-->avi). I have been using it and it's easy and works. Download trial version from http://www.xilisoft.com.
Convert AVI to 3GP with Minimum frames-per-second
By JamesC2000 in forum Video ConversionReplies: 1Last Post: 7th Nov 2011, 15:23 -
Converting 3gp to MPEG4 .AVI
By vworley in forum ffmpegX general discussionReplies: 9Last Post: 2nd Apr 2008, 13:48 -
FFMPEG 3gp conversion
By diskontrol in forum Video ConversionReplies: 1Last Post: 19th Dec 2007, 04:50 -
3gp conversion problem
By nddcndndd in forum Portable VideoReplies: 5Last Post: 20th Oct 2007, 14:15 -
ffmpegx.... 3GP conversion= bad quality
By PIZZ in forum ffmpegX general discussionReplies: 1Last Post: 7th May 2007, 12:04
