I was wondering can I fit more video using mpeg 1 instead mpeg 2 on a dvd? Quality really is not an issue on this dvd. I was looking at the settings in tmpgenc and I saw something about 495 minutes on a dvd with mp2 for the sound. What determines how much movie will go on a dvd?
Originally Posted by gotenks98
And conversion/encoding isn't authoring so I'm moving your topic. -
a vcd-compliant mpg1 will have a bitrate of 1150Kbs for video. You can have the same bitrate in an mpg2 file as well. as long as your GOP parameters are correct and the audio is 48Khz, the mpg2 will work just fine in DVD authoring programs. Personally, with the same source > product, I think an mpg2 will look a little better/cleaner then mpg1, but that's probably a bit of an arbitrary call.
495 minutes seems a bit high, I've had a couple of vcd>dvd projects that have had around 430 minutes, but maybe you can gain more by jacking down the audio......hmmm, maybe for mpg2 you could even drop the bitrate below 1150.....I've never tried it.
want to capture directly to ffdshow mpeg-1 or mpeg-2 for dvd
By wolfdogg in forum Capturing and VCRReplies: 10Last Post: 10th Jan 2012, 07:23 -
DVD to an edited MPEG-2 file with MPEG audio: Trouble/please help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 9th Aug 2011, 08:52 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
MPEG II to MPEG (DVD): Transcode or reencode?
By Jeroen1000 in forum Video ConversionReplies: 8Last Post: 12th Feb 2009, 17:44 -
MPEG-1 to MPEG-2 to DVD Advantages/Disadvantages?
By louv68 in forum Video ConversionReplies: 4Last Post: 7th Jul 2007, 16:51
