Results 1 to 14 of 14
  1. I stumbled across this and although I dont think this is really an "easter egg" it did work for me. I have a G4 iBook and and an external dvd burner I can now use with iDVD.
    http://forum.firmware-flash.com/viewtopic.php?t=23370
  2. i can't speak to the burning with external drives, but iDVD4 already can create a disk image. That's one of the touted features of the 4.o release.
    william
  3. Without an Apple superdrive installed, iDVD will only let you create a project and archive it so it can be be put on a mac with a superdrive. It wont let you burn to an external drive or create a disc image of the final project.
  4. Does it work with iDVD 4.01 or just version 4? I don't have iDVD infront of me to try it out...
  5. It works with 4.01
    Dec 2003
    Eugene, Oregon
    Mike at xlr8yourmac.com just confirmed that it worked with his external Plextor drive.
  7. If anyone has any experience wih this, please post about it.
  8. My dvd drive (Pioneer 106) is internal. so I can't comment on this fix providing ecxtra support for external drives. It did not add the ability to save as a .dmg file.
    When the file is downloaded and decompressed I get two Photoshop PICT resource files—without any PICT information in them. Is this what other folks are getting? And has anyone gained the ability to save/export to .dmg?
    william
    Dec 2003
    Eugene, Oregon
    Here is some of what Mike posted on his xlr8yourmac.com site regarding this:
    "The download file ... unstuffs to 2 files in a folder (w/Adobe PICT resource file icons) - copy them (not the folder) to your root user folder, then launch iDVD and when pressing the burn button - hold down the 'Control' key."
    Oct 2003
    Canada
    Made an .img of the tutorial that comes with iDVD since I don't have an external drive, and was able to test in DVD player and VLC.
  11. I have G4 cube, external firewire Pioneer DVD R 104 Drive.
    The above easter egg works!
    Thanks for the early presents.
  12. Couple people said iDVD4 can create a disk image instead of burning a disk. How?
    I can't find any option in the menus or in the help files.
    Dec 2003
    Eugene, Oregon
    weirsbaski, as pointed out above by buddy2000 iDVD4 only allows you to work on the project and save the project file with your non-superdrive Mac. It doesn't let you save a disk image. At least that was true until the files that are linked in the top-most post. Install those files in your User folder and hold down the control key when you click burn in iDVD. This opens a menu that allows saving a disk image or burning to an external DVD drive. I suspect the external DVD drive needs to be fully supported for burning with iApps and, of course, you must use DVD-R media (a requirement of iDVD).
    Apr 2003
    william
    Me too. I have a internal DVD drive and when I did the control-click thing, no pop-up dialog came up.
