please help...how do you automaticaly change the default of which aspect ratio format is being played when the "play movie" button is selected?. i ripped out the fullscreen so only the widescreen is present and the default choice is fullscreen which isn't present.... so the only way it will work is if i setup the DVD first by selecting the widescreen format and then going back to the main menu and playing the movie. if i hit play movie before i change to widescreen the movie just hangs
the movie is for my daughter "barbie as rapunzel"
