  1. Hi, I have an movie on my computer that I want to burnb onto a DVD-R disc. It is an AVI file. The movie is 352 by 240 pixles. I want it to be the best quality that it can be on a DVD-R perferably a DVD not a VCD but i dont know. Since its only 352x240 I dont know if I will be able to watch the movie on my tv without it looking like crap. I have searched guides on this site but i couldn't find any. I have TMPGnc DVD Author and TMPGnc plus 2.5. If somebody could help me that would be great thanks!
    THANKS!
    Convert to dvd mpeg2 352x240, it will be dvd compliant. If you are using the tmpgenc wizard select dvd ntsc low resolution. It is no point to convert to higher resolutions, garbage in garbage out.
