Any chance the quality will be better if I decide to convert my VCD to a DVD+R? I would assume that the quality will be the same on a DVD converting from a VCD, but that's only my assumption. I wonder if there is a way to make the picture look better on a DVD converting from a VCD.
Any help is appreciated.
ljCharlie
Results 1 to 10 of 10
It will not look better. In fact, if you try converting the vcd 720x480 mpeg-1 to mpeg-2 it will look far worse. You're better off resampling the audio to 48000hz using an authoring program. There's no need to convert the video, as it's already DVD compliant in terms of resolution.
Thanks for the suggestion. I'm not sure what resolution my VCD is in but I believed it's not 720x480, it is something by 320 only. That is why I wonder if I covert or resample to 720x480, will the resolution get worse or better since it was originally record at 480x320, I think?
ljCharlie -
Forgive my mistyped previous reply. What I meant was that if you converted your VCD mpeg-1 (which is probably 352x240) to a DVD mpeg(720x480 mpeg-2) the quality would look terrible. You are better off leaving your mpeg as is and merely re-sampling the audio so you can author it to DVD.
Thanks! One more thing, why I would want to resample the audio track? What's the benifit in that?
ljCharlie -
Because you have to. All DVD audio is 48 khz. Whereas VCD/SVCD is 44 Khz.
VCD MPEG1 video is DVD standard (as opposed to SVCD MPEG2 which isn't). However, VCD audio isn't standard at 44 Khz. If you resample (but leave it MP2) it to 48 Khz, then you can author it as DVD video.
Don't convert the video, it will only look worse.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Thank you. I'll give that a try.
By the way, since VCD quality are a lot lower than DVD quality, it is possible to put in like 4 VCD worth of material in one DVD+R by using Adobe Encore, correct?
ljCharlie -
Originally Posted by ljCharlie
As far as possibly converting the video from mpg1>mpg2: while it's true that you would be recompressing and as such would technically degrade quality, it is also possible that you could "improve" the video.
By that I mean if your vcd has some appearence problems, an application of filters during the re-encode can help. I've had vcd compliant mpg1 that was too dark/light or too much/little color saturation and by applying the contrast and brightness filters or saturation filters in TMPGEnc, sometimes along with sharpening the images, I've improved the 'watchability' of the video. I'm not claiming I have improved the quality.....just some arbitrary aspects of the video.
There is also no "rule" about the resolution having to be full dvd spec. When I've done this, the resultant MPG2 has had a resolution of 352 X 240 with an 1150Kbs bitrate. So you don't have to drastically degrade the quality by quadrupling the resolution, as was the example discussed in this thread.
Rip VCD to ISO without converting
By cynikalhedonist in forum Authoring (VCD/SVCD)Replies: 9Last Post: 11th Mar 2011, 12:50 -
converting vcd to DVD/blu-ray with upscale
By KePadma in forum Video ConversionReplies: 1Last Post: 18th Nov 2010, 15:13 -
Converting Xvid to MPEG1(VCD)
By Ensign in forum Video ConversionReplies: 3Last Post: 18th Dec 2008, 15:00 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Poorly sized video on converting VCD to DVD
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 31st May 2007, 01:39
