  1. Greetings All,
    I was looking for some help on this, I have a LARGE DVD9 I want to backup to a DVD5. I tried dvdshrink, but it's too large cause I see macroblocks on the copy. I would like to take it and convert it 352*480 with the menus and AC-3, but I cannot find any guides to follow. Can anyone please put me in the right direction to solve this.
    Steve
  2. Member Ziffelpig's Avatar
    May 2003
    Soviet Canuckistan
    Open Tmpgenc, click on load,open the extra folder and click and unlock the mcf. Then go to settings and create your half d-1 template and save the new settings to whatever you want to call your template. Then load your file, then load your new template- encode
    Just shut up and listen dumbass
  3. Thanks Ziffelpig,
    But then how do I connect the menus to work again, and what do I do with the AC-3 soundtrack?
