I use TMD author which I find easy and efficient but. (the inevitable but) When a movie is too long how do I get it to fit without cutting bits out? Is there a program which can condense it? I don't want to use nero because it takes forever. Any suggestions please?![]()
When make a dvd that is a bit big using TDA I use DVD shrink to fix that problem.
They are mpeg files that need authoring to DVD. Done others on TMP
DVD author. Its just when they are too long. I have already converted from avi files to mpeg.
DVD Authoring with Windows MM 2.6 OR AVS Authoring
By jagman in forum Authoring (DVD)Replies: 3Last Post: 8th Oct 2011, 05:41 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 20:16 -
TMPGEnc Authoring Works v.4.0.4.24 - Authoring
By niteghost in forum Authoring (DVD)Replies: 8Last Post: 21st Jul 2009, 22:15 -
Great Article On Current BD Authoring Solutions & Future Mac Authoring
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Dec 2008, 18:04 -
TMPGEncDVD authoring 3 with divx authoring
By buttzilla in forum Authoring (DVD)Replies: 0Last Post: 11th May 2007, 22:51
