Results 1 to 9 of 9
I had got this same type of packaging in OM ie black bottom and it turned out to be RICOH. But i have heard varying stories.
I sent email to Amazon and they said to call Memorex directly.
I called Memorex and they said they cannot verify.
I might have to cancel the order. I just don't want CMC. -
Just got delivery of 2 spindles. They are Ricoh +R discs according to DVDInfoPro.
From various threads (here and other boards), user reports and my own experience, I have concluded that there is nothing wrong about the CMC MAG F01 media (4x DVD+R).
I get great burns, and others have reported likewise either. A lot of bad press following CMC have been due to their previous dyes and discs but these newer ones are certainly quite respectable and hold their own.
The one downside as compared with the Ricoh discs is that they will burn at a max of 4x. The ricoh;s burn at 6x on my NEC ND-2500A and Plextor and a few others will burn them at 8x. While they may be ever so slightly better, there is certainly nothing wrong with the CMC's.
Try them and form your own opinion. Don't always go by what you hear throught the grapevine. :P -
Are they from Amazon? Are they 100 DVD+r spindle that look exactly like the above link I provided with?Originally Posted by jamerican
__________________ -
Well I bought 2*25 packs of Philips dvd+r with cmc dye. I burnt the first 25 and they did work on my Philips, but this player plays almost everything. However they didn't play correct on two of my friends players, lots of pixelisation and freezing all over the movie.Originally Posted by porphyra
I returned the other 25 and bought RitekG04 and Ricoh disc instead and they seems to work even on the picky dvd
. So I guees that you can't compare CMC with Ritek and Ricoh!
Verbatim Life Series DVD-R Spindle - Oh no, CMC!
By ckdexterhn in forum MediaReplies: 16Last Post: 9th May 2011, 09:44 -
CMC MAG M01 vs CMC MAG AM3 -- Difference?
By Calidore in forum MediaReplies: 10Last Post: 25th May 2010, 09:15 -
Pioneer DVR-220S and TDK (CMC MAG, AM3) discs incompatible?
By cwerdna in forum DVD & Blu-ray RecordersReplies: 4Last Post: 12th Nov 2008, 15:25 -
CMC holds off on Blu-ray Disc production
By ebenton in forum Latest Video NewsReplies: 11Last Post: 8th Mar 2008, 20:47 -
REMINDER--DON'T use CMC made Crap discs/MEMOREX
By Lobe in forum MediaReplies: 1Last Post: 27th Nov 2007, 23:29
