Hi everyone,
I am going to make the jump from SVCD to DVD burning by buying this burner today it's on sale for $96.00. My question is should this be a Slave or master drive? I already have a DVD drive as my master. I only ask because some have told me to switch and have the burner be the master.
Thank you and I hope I put this in the right forum.![]()
the burner's installation instructions should tell you.
Always check helpfiles/instructions before leaping... -
Thanks. I know it says to hook it up either way but master is better. Just wondered how other people out there have it set up? I went ahead and set it up for master. I just have to remember that when I go to burn a CD to put it in the top tray. I am in the habbit of puting it in the bottom tray.
Habits are easy to break.
Hey, I've been smokin' for over 40 years, and quit dozens of times.
You'll learn, specially when it says "No disk", or "Insert burnable Media".
Cheers,
George
Lite-On Burner Will Not Read DVD+R Media
By kca741979 in forum MediaReplies: 11Last Post: 28th Feb 2010, 02:47 -
Slow Data Transfer from Slave to Master
By jollyjohn in forum ComputerReplies: 15Last Post: 9th Oct 2009, 01:48 -
is the lite on cd-burner toast??
By gentlejax in forum DVD & Blu-ray WritersReplies: 3Last Post: 22nd Feb 2009, 16:02 -
Gateway AR-230 flashed to LVW-5001 , DDW-451s to LDW-451s, SUCCESS!
By FiremanPete in forum DVD & Blu-ray RecordersReplies: 1Last Post: 28th Jun 2008, 22:15 -
Which Burner for do I set as Master/Slave
By mn072065 in forum DVD & Blu-ray WritersReplies: 12Last Post: 17th Apr 2008, 10:46
