A friend purchased a computer at a local show where they assemble them while you wait. He was supposed to get an xp3100 but has found it to be an xp3000.
I've tried searching the AMD site, but it didn't seem very easy to find the info. Is there a significant difference between these processors?
Thanks.
Results 1 to 11 of 11
it depends, 333mhz or 400mhz fsb?, 2.167 gighz or a little more than that?
overall, probably not a big difference, but if he didn't get what he paid for, then make them fix it! -
Originally Posted by Piccoro
This is straight from www.newegg.com
Specification
Model: AMD Athlon XP 3000+
Core: Barton
Operating Frequency: 2.16GHz
FSB: 333MHz
Cache: L1/64K+64K; L2/512K
Voltage: 1.65V
Process: 0.13Micron
Specification
Core: Barton
Operating Frequency: 2.1GHz
FSB: 400MHz
Voltage: 1.65V
Process: 0.13Micron -
You can get a 3000 or a 3200, but there isn't a 3100
"Terminated!" :firing: -
I don't know, those shows are pretty bads with counterfeit/remarked chips, but what kind of person would advertise a sytem with a non-existent chip?
Just to let you know that there is a 3100+ AMD cpu that is factory tuned from ECS, the k7vmm3,it is fairly new and I own one.
Factory Tuned? Sounds like Factory Overclocked to me. Matter of fact a quick google search showed nothing on that part nubmer other then a system board... like I said check with AMDs site, its the final word. The chip doesn't exist unless its over clocked and renamed.Originally Posted by carrachu
Take it from someone who was just out shopping for the higherend Athlon XPs, there is no AMD offical XP 3100+
There is a 3000+ that I think has 2 different bus speeds depending on which you get, and a 3200+ that is a 400mhz FSB chip. But no 3100+ unless its either an overclocked 3000+ or an underclocked 3200+. -
Update to both threads with the 3100+ cpus.
I found 3 references to it on the web.
1) someone selling one on ebay, could mean anything
2) what appears to be a CPU road map thats old enough to not include the 3200+ on it. and...
3) An article talking about how HP is selling an Athlon *64* 3100+.
Beyond that I find squat and on top of it, ECS website has nothing either. -
Uh-oh! https://www.videohelp.com/forum/viewtopic.php?t=210997Originally Posted by carrachu
Ex-AMD engineer rips AMD management
By deadrats in forum ComputerReplies: 0Last Post: 17th Oct 2011, 19:39 -
AMD Phenom X4 9500 vs AMD Phenom II X3 710
By kenmo in forum ComputerReplies: 16Last Post: 1st Apr 2009, 21:03 -
AMD or Intel??
By caesarhawy in forum ComputerReplies: 15Last Post: 13th Oct 2007, 23:47 -
AMD 64 4000+(1x2.4GHz) or AMD 64 X2 3800+ (2x2.0GHz)
By neomaine in forum ComputerReplies: 19Last Post: 13th Jul 2007, 11:24 -
AMD forums
By gmcman in forum Off topicReplies: 1Last Post: 9th May 2007, 22:27
