when I try to open a video source with TMPGEnc, it says "Cannot open, or unsupported"
is there anything I can do to convert this avi file to mpg?
thanks a lot
You have to go to options in tmpg and enviromental settings,raise the priority of the avi plugins.
also ... try to reinstall the AVI - DIVX codec
also ... try to remove the sse2 ... it always , when i got this error help ! -
I already raised the priority, still doesn't work. how do I reinstall the avi divx codec? and remove sse2?
Yep, check the DIVX codec. You need a codec 47 or something like that.
Can not open any file in TMPGEnc 4
By Soixante in forum Video ConversionReplies: 4Last Post: 8th Sep 2010, 08:56 -
can't open file in TMPGEnc
By windranger in forum Newbie / General discussionsReplies: 12Last Post: 18th Feb 2009, 09:25 -
failure to convert flv to Avi file because of unsupported video codec
By 2thvideo in forum ffmpegX general discussionReplies: 10Last Post: 30th Jan 2009, 12:54 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
cannot open or unsupported file on tmpgenc
By Donna Stefani in forum Video ConversionReplies: 6Last Post: 15th Aug 2007, 20:31
