When I try to encode an DV-AVI-Stream to mpg2 using TMPGEnc 2.5 with VBR exactly in the middle (50%) of the process TMPGEnc closes without any message. I'm using XP as OS, the Mainconcept DV-Codec and MSP7.01. What can I do?
Thanks, dlawedor
In the middle of every difficulty lies opportunity. Albert Einstein
That happens when the codec doesn't support reverse seeking
properly. TNPGenc is trying to seek to the beginning of the file
for pass #2. Dunno whose fault that is. Try Panasonic or another codec -
Hello Foo ... but it worked with the Mainconcept Codec until 2 or 3 weeks ago ...
Thanks in advanceIn the middle of every difficulty lies opportunity. Albert Einstein -
You might try frameserving the video through Vdub , or just
open with Vdub and see if it seeks in reverse
Need help with virtualdub error involving VBR encoding
By Hark in forum EditingReplies: 16Last Post: 12th Feb 2010, 00:45 -
Virtualdub has detected an improper VBR audio encoding
By lingoguysw5 in forum AudioReplies: 17Last Post: 26th Oct 2009, 11:12 -
VBR (2 pass, average bitrate) Encoding for DVD-9
By jcm0320 in forum Video ConversionReplies: 3Last Post: 15th Aug 2007, 10:44 -
VBR encoding problems with TMPGEnc 4XP
By maccool111 in forum Video ConversionReplies: 2Last Post: 8th Jun 2007, 05:42 -
Need help with ffmpeg 2-pass VBR encoding
By SliderVF14 in forum Video ConversionReplies: 8Last Post: 14th May 2007, 19:03
