  1. I have just ripped finding nemo to my hard drive usung dvd shrink, what program do i use to burn it onto a dvd-r? Have tried nero recode and i get an error messeage saying my trial has expired but its the full retail version.
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Use imgtools classic to create the iso image. Burn the image with DVDDecrypter. All nice and free tools, and the best for the task to boot.
    /Mats
  3. I Just used the imgtool you said about and it states that my media is not blank but it is, whats the problem?
  4. DVDShrink can burn with the Nero 6 API.
    JoNty
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    imgtools classic shouldn't even care about your media, as it's used to create a DVD image on your HDD that you then write to disc with DVDDecrypter...
    /Mats
  6. I just started to use the latest versions of shrink and DVDDcrypter this weekend . With shrink, make sure you have the options to create an iso image and to go to DVDDcryptor set. (Also, I don't have Nero so I set the switch not to go to Nero. I don't know what will happen if you have Nero and set the default to go to Nero but want to go to Decrypter.) Anyway, after going through the initial analysis in shrink, set it to do a backup and it will burn automatically using Decrypter. Make sure you have a blank DVD in the burner and are reading the original from another drive. Good luck.
