  1. Hello guys !
    Do somebody know how to force tmpenc plus encode avi file with ac3 ?
    I tried many way but only could encode movie stream only !!!
    With VirtualDubmOd i could demux ac3 file with avi, but when authorizing with Dvd-lab, all the time the DvD-Lab's error appear and said me that my files have problem and cannot continue, althought i tried to demux them in Dvd-Lab !!!
    Somebody know ?!
    Ps: Which author program allow to put subtitles track in the movie that can select in the dvd-player remote control ???
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    It can't. Period. You have to extract the AC3, then decode to wav before encoding with TMPGEnc.
    VDub adds some wav headers in the AC3 even if you save direct stream, so before using it, it has to be run thru AC3Fix.
    Anyone that can author subtitles at all. I use IfoEdit.
    /Mats
  3. Thanks alots , but DVD-lab still refuse my avi files and i dont know why
    Mux with IFOedit ok, preview with PowerDvd oke, but when trying to author with Dvd-lab, could not, then i tried with tmpenc author, its oke, but no subtitles there (
    What i have to do now
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    After using IfoEdit, you're done authoring. No need for calling up DVD-Lab.
    Just make image and burn!
    /Mats
    (And before you ask - no, you can't get menus with IfoEdit, and you can't get subs with DVD-Lab. It's either or. But who needs a menu for a one movie DVD?)
  5. Again, thanks for answer me
    Oke, i know that im done author with IFOedit, but because my movies has few chapters, and i want to make menu for them, then i must use Dvd-Lab to author them again with menus , im clear here ?
    With Vobs files encoded by IFOedit with sub, when i tried to play them in PowerDVD, its ok with Subtitel, but when import those Vobs file into Dvd-Lab, hmm, DVD-lab report me that my Elementary movie stream has problem and cannot continue, but im still confusing what kind of those errors ^^
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Can't help you any further then, 'cause I've never done anything with subs and menu. I decide what's more important to me, and then make my choice of authoring method.
    /Mats
  7. Thanks, you can try Dvd-Lab and IFO-edit with Subtitel here :
    https://www.videohelp.com/forum/viewtopic.php?p=655210
    If you found out something, please tell me
