I'm having the following problem: i've joind some subtitles to divx (with virtual sub) and when I tried to encode to vcd (mpeg1) and spit with TempEnc no problem, but when i tried to record with Nero 6.0, the format (mpeg1) does not play's on the domestic DVD. Is there any possibility to split the file not using the TempEnc but the Virtual Dub or any other program? P.S. When I burn splited files with Nero and convert them in VCD that works.
Thanks![]()
Love rules!
Thanks for your help. But can you tel me a tutorial how to do it?I'm stil a beginer. And that help that you sent me is a bit vage. Thanks
Love rules! -
read the guides under AVI to VCD - there are plenty.
In short:
Load your AVI and subs (using the subtitler filter) in VirtualDub. After the subtitler filter, add the resize filter and Lanzcos resize to VCD resolution.
Click the "set start marker" button. Drag the slider half way, click "set end marker". Make a note of end frame number.
Start frame server and encode with TMPGEnc as VCD (If unsure on this step, there's a good guide on frame serving with VirtualDub)
When finished first encode, without moving the slider,click "set start marker". Then move slider to the end of the movie (far right) and click the "set end marker" button.
Repeat the frame serve & encode part.
/Mats
MOV: Editing: Joining/Cutting/Splitting software
By taboo in forum EditingReplies: 5Last Post: 8th Aug 2011, 18:59 -
editing video - cutting a few minutes at the beginning and end
By hardy in forum Newbie / General discussionsReplies: 6Last Post: 30th Jun 2010, 17:19 -
H264 Editing and Cutting - Apple h.264 settings needed
By bsti in forum MacReplies: 0Last Post: 17th Nov 2009, 07:27 -
Cutting a M2V file or editing SINGLE FRAMES of it
By lorix in forum EditingReplies: 3Last Post: 13th Nov 2008, 03:05 -
Is there not something better than virtualdub for divx cutting?
By pondleaping in forum EditingReplies: 23Last Post: 5th Jun 2007, 11:45
