Hello to you all,
i have the next question:
i have got two systems with same burners and readers
System1:
Pent4 1,8Ghz
256mb DDRam
NEC1300 Burner
Pioneer Reader
system2:
AMD 2200 (1,8Ghz)
256 mb DDRam
NEC1300 Burner
Pioneer reader
When i burn on system 1 it takes about 15 minutes to copy a dvd.
When i burn on system 2 it takes about 40 minutes to copy a dvd.
Both burn programs are nero6.
When i write a image system 1 writes the image between 5.000 and 12.000kb/s
But system 2 writes between 0.500 and 2.900kb/s!
How is this possible???
Not detailed enough. At first glance, I'd say media speed.
ok, not detailde enough.
i think your answer isn't detailed to. What else do you need to know to give me an answer on my question.
gr -
At first glance, this sounds like a DMA issue. Check to see if DMA is enabled on the IDE channels for your drives.
Dma is enabled i suppose.
i enabled the dma from the ide channels. After this he copied an image much faster. But copying from dvd to dvd still is very slow.
Are there some other settings i have to take care of?
Is there any difference between nero and easy cd creator?
I use memorex dvd's and they burn very fast in the first pc.
In the second one it won't work how it has to work!
gr -
If the speed issue remains now only on disk to disk, is the "on the fly" box ticked ? .... I think Nero 6 calls it "Quick Copy"
Yes thats enabled.
I think the problem is solved.
I have formatted my harddisk and installed Win ME. Then i installed nero with the best ISAPI i could found.
I Enabled DMA and the problem was solved.
I tried these things also with Windows SBS 2003 and it didn't worked.
gr
vob2mpg, 1st try, two different machines, neither work
By Hoooooooar in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 11th Jan 2010, 23:26 -
Using avisynth on two machines
By CogoSWSDS in forum EditingReplies: 1Last Post: 26th Dec 2008, 22:40 -
VHS to DVD Combo Machines?
By JXBlack in forum DVD & Blu-ray RecordersReplies: 2Last Post: 29th Nov 2008, 10:12 -
Do you use virtual machines on your computer?
By yoda313 in forum PollsReplies: 29Last Post: 20th Mar 2008, 15:56 -
Problem Writing Dual Layer (first time attempting DL)
By brett0973 in forum Authoring (DVD)Replies: 5Last Post: 9th Nov 2007, 21:46
