As the title, really, I've got several captures from a nebula DVB-T card. I've used PVAstrumento to convert these into PS mpeg files (from TS). These load into TDA perfectly and I have cut them to the right lengths etc. I then output them and burn them with nero to DVDRW. When I try and play them in my Sony 900 stand alone they work but have no ausio, when I try them in my PC they are perfect, also when I try them in my Xbox they are fine. Why can't the stand alone find the audio?
Owain
Is it mpeg audio? Then test to set the audio output to PCM in your sony DVD Player under audio settings.
Nice one! Thanks for that, all I had to do was set the MPEG output to PCM instead of MPEG and it all works fine.
Cheers
Owain
recording 1080i from dvb-t usb tuner - best practices
By codemaster in forum DVB / IPTVReplies: 1Last Post: 15th Mar 2012, 03:10 -
DVB-t300 schedule recording problem
By sharkbite in forum DVB / IPTVReplies: 0Last Post: 23rd Aug 2009, 19:59 -
Automated recording from DVB receiver card (in Windows)
By Thrasher0815 in forum DVB / IPTVReplies: 1Last Post: 7th May 2009, 09:59 -
Audio Glitches when Recording DVB-TV only
By jfcooper in forum Newbie / General discussionsReplies: 0Last Post: 24th Nov 2008, 04:43 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 18:46
