Hi,
I have a .m2v that has the same parameters as the original stream contained in a VOB: same width, height, aspect ratio, framerate, interlacing, frame count, even GOP structure (the I/P/B frames come exactly in the same order). The only things that differ are the quantization tables, and (obviously) the quantizer scale codes.
When I try to remux the new stream with IFOEdit, the output video suffers from an occasional stuttering, approx. once in every 15-30 seconds. But when I author a DVD with this stream, it plays as smoothly as it should. This happens both on my set-top player (Panasonic), and on my software player (PowerDVD).
What am I doing wrong? I tried with and without the "Rebuild PTS" option, and "Correct VOB-Unit pointers", "Correct original IFO files". Could it be a bug in IFOEdit (ver 0.96)? What else can I try? I understood that VOBEdit does not readjusts the IFOs. Is there another tool that I can try?
Or, a related question: what does ReMPEG2 preserve, other than spatial/temporal parameters (width, ...) and GOP structure? I understood that the video streams produced by ReMPEG2 can be remuxed without problems?
Best regards
Cosmin
Thanks... I tried it several times, but, unfortunately, it didn't work. In fact, when I used VOBEdit, the stuttering became even nastier. (With IFOEdit, it is only slightly noticeable).
There is something to be mentioned, though: VirtualDubMod shows lots of warnings like "Anachronistic or discontinuous timestamp found in audio stream 29 at byte position nnnnnn (may indicate an improper join)", when loading either the original VOB, or the remuxed one. The original plays fine, but the remuxed one does not.
Thanks for the help anyway. I wonder if there are other remuxing tools (TMPGEnc is good for remuxing, but not for VOBs...) I think I'll ask 2COOL about this.
Best regardsCosmin
Remuxing Results in MKV Audio-Video Sync Problem
By gonwk in forum Newbie / General discussionsReplies: 5Last Post: 26th Apr 2012, 20:51 -
Problem remuxing with multiAVCHD
By jadasneez in forum Authoring (Blu-ray)Replies: 2Last Post: 13th Jan 2012, 16:08 -
A/V sync problem when remuxing (AverMedia mpg file)
By matomato13 in forum Video ConversionReplies: 8Last Post: 25th Mar 2011, 21:48 -
Problem editing IFO using IFOedit
By cooldude859 in forum Newbie / General discussionsReplies: 4Last Post: 5th Nov 2009, 16:54 -
Problem with remuxing with MuxMan
By omega6666 in forum Authoring (DVD)Replies: 13Last Post: 25th Aug 2007, 17:14
