My problems is that a have recorded some AVI-files from my TV-tuner card. The audio is out-of-sync.
I need a program where i can "move" the audio-track, and see the result before converting to DVD.
Here's what I do. Check the AVI file after I create it from my tuner card (at a couple different spots in the movie). If it's off, I use virtualdub to adjust the delay. I then save off a small piece and "eyeball" it to see if the words match the mouths. Nothing scientific, but that's what I do...
Avi: fine, DVD: audio out of sync
By Sebastian2011 in forum Authoring (DVD)Replies: 2Last Post: 22nd Jan 2012, 13:32 -
Avi to DVD - audio goes progressively more out of Sync
By UnknownVT in forum Video ConversionReplies: 9Last Post: 11th Jan 2012, 13:33 -
AVI to DVD: help with audio sync problems
By tanglemac76 in forum MacReplies: 9Last Post: 23rd Dec 2010, 14:50 -
Avi to DVD and Audio Sync Issue
By macbuz in forum MacReplies: 21Last Post: 11th Jan 2009, 19:04 -
audio sync trouble on dvd to avi
By zookeeper525 in forum DVD RippingReplies: 5Last Post: 2nd Sep 2007, 10:23
