hello,
i have a library of 15-40 sec qt files exported from fce as dv-pal with no audio,these are currently sat on my hard drive as i need fast access to them for daily fce projects,
problem is their taking up too much room so rather than put them onto mini dv tape can i burn them to dvd as separate qt files in relevant folders?i use fce and toast 6,i got dvd sp2 on order as well if that will help,if not,what software will do this?can't see toast 6 being much use here.
thanks in advance
luke
If you want to store these files in their current format and organized within folders, just use the Toast Data tab, drag in the folders and burn the DVD. It will be a data disc, not a movie DVD, but that's what I understand you're wanting to create.
thanks for fast response frobozz,
not got mac in front of me but just to confirm,if i follow the steps you provided,i'll be able to import qt files from dvd into fce?
didnt realize it was so easy!cheers -
the method of burning a DATA DVD results in the files just being stored on the dvd disk instead of your HD
lots of people (including myself) use DATA DVD to retian files but not have them be on the HD (as they are now stored on the disk)
just put in the blank dvd, open toast, choose DATA and set your format to MAC & PC. Then click NEW DISC and tile the dvd. now just start dragging your files into toast's window and burn
resulting dvd is data dvd, not video dvd
it can be accessed at any time just like a hd as long as its in the drive
Best way to archive video files?
By preacher238 in forum Video ConversionReplies: 57Last Post: 31st Dec 2012, 12:17 -
Can HDD Blu-ray DVD player archive DVD and video files?
By coody in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Sep 2010, 12:19 -
hows video playback on ps3 with ubuntu
By biggyk in forum LinuxReplies: 2Last Post: 11th Feb 2009, 14:06 -
Hows JVC Everio GZ-HD10 vs Sony's HDR SR10
By Squid267 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 17th Dec 2008, 19:24 -
Want to archive my DVD library to my HTPC
By Memo_182 in forum Media Center PC / MediaCentersReplies: 3Last Post: 26th May 2008, 20:45
