What type of DVd are the once that you buy in the movie sstore. Are they - or + or are they both?
i wish i can buy those so i dont have to worry which player supports - or +
cuz im having a hard time getting my backup copies to play on the apex ad-1201 player. but when i buy from a deal that is not authorize his dvd's all anyway play i cant tell if his dvd is - or + i wonder
Originally Posted by deedogz
I'd ask to talk to the manager if I were you."There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
these discs would be useless to u ne way as they are printed and not burned, and usually dual layered
You would not be able to burn on them, they are dual layered.
The discs you see in the "movie store" are MANUFACTURED for that specific movie in a pressing plant.
For further info, look into the difference between "duplication" and "replication."
You would not be able to burn on them, they are dual layered. -
Commercial DVD's are pressed, they are neither + or -
https://www.videohelp.com/forum/viewtopic.php?p=837642#837642 -
Since we seem to be posting in redundancy mode...I will chime in as the sixth person to say..."No...you can't since they are pressed/stamped and you probably wouldn't want to spend 6 figures to purchase a machine that could utilize them"
No, I'm from Iowa. I only work in outer space. -
Originally Posted by babyboo
Can't Read DVD+RW with XP
By Ailanthus in forum MediaReplies: 7Last Post: 13th Nov 2010, 04:44 -
Create DVD with TMPGEnc DVD Author 3 and not read on DVD Player
By Salutatous in forum Authoring (DVD)Replies: 1Last Post: 22nd May 2008, 10:22 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 17:59 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 16th Jun 2007, 23:04
