I am using Ifoedit for create VOBs... I used TMPGEnc for creating MPVs and BeSweet to convert MP3 into AC3. Later both this files are used in Ifoedit to create VOBs.
unfortunately audio doesnt sync with video.
The original mpeg was created from Sony Vegas from which mpv was generated.
any help on how to fix this audio sync problem appreciated.
thanks
Well it seems that video/audio sync is the most common problem.
I never saw a good answer, so please allow me to repeat my answer to someone else:
One of the reasons audio and video is out of sync is caused by the DVD player not being fast enough to handle the bitrate.
This specially happens when you create your own video (not just copying a DVD movie to another DVD), and (re-)mpeg it. As you probably want to get the highest quality possible, the codec will generate a file with a very high bitrate. Many (stand alone) DVD players simply cannot handle these high bitrates.
At least that's what I found out after going completely crazy and blaming my software, my burner, my TV, etc! I always thought that it couldn't be my DVD player, as it would play copies of DVD movies (burned on the same media) without a problem.
So, try to find a setting to limit the bitrate.
Good luck!
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
AutoGK, Audio Sync problem.
By steve_hawthorn in forum Newbie / General discussionsReplies: 2Last Post: 22nd Dec 2009, 00:39 -
Audio Sync Problem
By lwea2009 in forum Newbie / General discussionsReplies: 8Last Post: 30th May 2009, 15:19 -
out of sync audio problem
By virendra in forum AudioReplies: 2Last Post: 25th Dec 2007, 06:31 -
New (?) audio sync problem
By oldblues in forum ffmpegX general discussionReplies: 3Last Post: 26th Oct 2007, 10:26
