Ok, I have a live concert that I am reauthoring because it has mpeg sound and my surround won't play it very well. I am converting the audio, obviously, to ac3. The first problem I am having is that when I set my audio to convert to ac3 it makes the dvd just a tad too large...I just ignore the problem and will probably transcode it when its done (the vid quality is only ok to begin with). SO when it's done i go to burn it, but guess what? It seems that the authoring process has converted less than half the dvd! I go to my folder where my output is created and it is only 1.7 gigs or there abouts! i have tried this 3 times already and the same thing keeps happening!
Any help?
EDIT: Just went through it again...It seems to stop at exactly 1.71 gigs...i dont know what the problem is....Is there a different way to convert the audio?
Boy do I love my avatar!
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
Strange region problem with DVD Shrink re-author
By Jetter68 in forum DVD RippingReplies: 7Last Post: 30th Aug 2008, 15:14 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07 -
Strange error message when re-authoring with TMPEGEnc DVD Author 1.6...
By justin81 in forum Authoring (DVD)Replies: 3Last Post: 24th Sep 2007, 02:23
