Are DVD-ROM drives the same as players in that some have compatibility issues? I have backed up many of my DVDs and they all play on my DVD player, but my Dell Inspiron 1100 and my Dell Latitude x300 laptops won't even recognize the discs. Any ideas on what to do?
DVD-R --- Meritline BeAll DVD-Rs
DVD Decrypter --> DVD2One --> CopytoDVD 8
Yep DVD-ROM drives can be picky about media, just the same as standalone players. Also some may not play dvdr's at all.
I'm not familiar with the media you are using, but you could try some Grade A disks, like Ritek G04's. These are known to be more compatible with a wider range of standalones, so they may make a difference .... definitely worth trying IMO. -
Also, I believe Dell is in the +R group along with HP/Compact. So the -BEall media your using probably wont work. I just had this issue with an LG DVD rom that I thought read both +/- but only reads -R.
I always have the same trouble ,but what I do is read the dvd where it was recorded from and it always works for me.. 8)
I had the same problem with my Dell Dimension 8250 and downloaded firmware from their website. Now I can play DVD-R's that I burned on my Panasonic DMR-E80. I found the Dell user forum very helpfull.
If you happen to have a Lite-On 16X DVD ROM Drive go to this site for the download. http://support.ap.dell.com/ap/en/filelib/download/index.asp?fileid=R53103
Good Luck,
Chris
Choppy playback on computer for a HF G10
By icoolyou in forum Newbie / General discussionsReplies: 2Last Post: 24th Feb 2012, 12:29 -
VHS to DVD+R playback on computer
By rchunah in forum Capturing and VCRReplies: 3Last Post: 9th Sep 2009, 10:37 -
Sticky labels can screwup the playback of your DVDR's
By Craig Tucker in forum MediaReplies: 556Last Post: 11th Sep 2008, 03:13 -
how to 'upscale' dvd playback on a computer
By slimselecta in forum Newbie / General discussionsReplies: 7Last Post: 28th Feb 2008, 15:03 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 09:19
