Hi, I am receiving an Buffer Underrun Error message when I try to burn DVD-R: "Writing was halted b/c data could not be sent to the recorder fast enough to maintain the current write speed. Please try again with a slower write speed."
Check speed numbers look good. I have tried 4x, 2x, 1x write speed - no luck with DVD-. DVD+ worked fine, but is not ideal for my mac.
Any suggestions for recording to DVD-???
I am using the TDK indiDVD 8x +/- 840G recorder on an ibook, OSX 10.3.2 (updated the iTunes/DiscBurner drive profile from TDK site), Toast Titanium 5.2. I am willing to upgrade, but only if software is the problem. If it's a hardware problem then I'd like to fix that (return & replace drive).
I can successfully burn to DVD+, but not DVD-. I have tried Memorex and TDK discs.
Thanks in advance,
Chris H.
The buffer underrun protection in Toast was broken in Panther with the +/- DVD drives. So Roxio released the Toast 5.2.3 update for Toast Titanium 5 users or the 6.0.3 update for Toast 6 users.
If you are using 5.2 then it's possible you have Toast Lite. In this case you need to download the Toast 5.2.2L update for Toast Lite at the Lacie support site.
Sense Key = Medium Error sense Code = 0x73, 0x03 in Toast
By arythmic in forum MacReplies: 37Last Post: 27th Nov 2012, 19:46 -
DVD Lab Pro Error: "Read data size is over the buffer limit"
By Motinha in forum Newbie / General discussionsReplies: 0Last Post: 29th Oct 2010, 03:49 -
Toast 9: The drive reported an error
By soundchaser in forum MacReplies: 16Last Post: 1st Jul 2009, 15:55 -
Toast error message on .cue files
By Going gray in forum MacReplies: 8Last Post: 17th Aug 2007, 13:46 -
LaCie / Toast / DVD+R DL Error
By webstar in forum MacReplies: 6Last Post: 4th Aug 2007, 12:53
