I have a source in 640x256 (2.50:1) PAL.
And I use
LanczosResize(704,412,0,0,640,256)
AddBorders(8,82,8,82)
I get 0,3% difference from the original aspect ratio ,in FitCD.
And I convert and resize to watch the output on a widscreen TV.
What would you use and why ??
Ok u don't have to explain why only what script u use when u have a source in 2.50:1 and if u resize it to anamorphic. And then play it on youre DVD player and widescreen TV.
I would use FitCD (and you already did use it) and let it generate an avisynth script. However I would enable macroblock aligned resizing to make it easier for the encoder. I would also set the destination resolution to 704x576 (XVCD) because it is a valid DVD-resolution and you have less black border to encode. I would also set 2 blocks overscan and crop-resize it to 672x416 with 16 pixels black border on left and right and
80 pixels black borders on top and bottom.
The reason of using a active picture size of mod32 pixels is that you can fill complete macroblocks with black around the actual picture area. The mpeg2 encoding is done on blocks of 8x8 pixels and macroblocks of 16x16 pixels. It requires more bitrate to encode a border edge within a block and within a macroblock compared to letting the border edges be aligned to the encoded macroblocks. This is not very important at DVD bitrates but when making SVCD it's good to make all optimizing you can. Since I started with SVCD before making DVD's I am used to always make macroblock aligned resizing when reencoding.
But all of this can be calculated with FitCD. An aspect ratio difference within 1 % or so can not be detected easily with the human eye. I would use the lanczos resize method because it gives a sharper picture than the other alternatives.Ronny -
Yees this is what I'm talking about
. Cause everybody has their own opinion and others can always learn something from them.
Thanks Ronnylov.
Yet Another Script - 2.0 to 5.1 Upmixer
By Soopafresh in forum AudioReplies: 201Last Post: 1st May 2012, 20:55 -
script ffmpeg ?
By lf2 in forum ProgrammingReplies: 5Last Post: 14th Mar 2012, 10:10 -
Need Help with My AviSynth Script
By Enkidu in forum Newbie / General discussionsReplies: 3Last Post: 21st Jan 2011, 21:37 -
To Script or Not To Script, that is the Question... (Custom Videos)
By TheMcD in forum EditingReplies: 2Last Post: 21st Oct 2010, 10:11 -
Does my script look right? I am trying a new script
By rocky12 in forum Newbie / General discussionsReplies: 11Last Post: 25th Sep 2008, 19:10
