TMGPEnc won't open the .d2v file, it says file format is not supported
It says to do the following in the guide to fix the problem
Be sure that you have installed the TMPGEnc VFAP Plugin. And you can also try to copy the DVD2AVI.vfp to the TMPGEnc folder, you find the DVD2AVI.vfp in the DVD2AVI folder.
I have both of those in the TMPGEnc folder and I checked the plugins setting in the program and they both showed up there. I go to browse and choose the *.d2v* file I want to convert to mpg and it says "TMGPEnc won't open the .d2v file, it says file format is not supported"
I did it the day before and it worked fine, but now it doesn't want to work. Any ideas? Please e-mail me or repost and let me know. Thanks
I've had this before, I run a duel boot system, and I do know that the system your running when you run your rip through DVD2AVI has to be the same system that you use with TMPGEnc. In other words if I'm running Windows 98 when I run DVD2AVI I can't load those files if I then start up into windows 2000. This is the only time I've ever had that problem
I ran into that problem when i deleted the orig vob's from the HD. I ripped them back to the HD and it worked fine
yes I think thats probably my problem, I deleted my .vob files to free up space. Thank you for your help.
Certain d2v file causing problems with MeGUI Avisynth Script Creator.
By Simcut in forum Newbie / General discussionsReplies: 5Last Post: 30th Jul 2012, 16:57 -
VirtualDub D2V file error
By Dr.Who in forum Video Streaming DownloadingReplies: 5Last Post: 17th Dec 2010, 14:23 -
avidemux won't open a DV .avi file
By BrianK in forum Video ConversionReplies: 2Last Post: 14th Jul 2009, 10:10 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08 -
Nero won't open .mp4 file
By ChickaJane in forum Video ConversionReplies: 8Last Post: 21st Aug 2007, 23:38
