Hi There!
Can anyone help me, by telling me what program i can use for joining and splitting AC3 sound that ripped from a DVD.
I`ve used Vobedit to rip the movie file in Movie, text, and sound files.
Now i need to find out what program i need to work on with the sound files.
supposedly there really easy to join, vobmerge i believe can do it.
[edit] probably filemerger also. -
The dos copy command!!!!
I use ..To append files, specify a single file for destination, but multiple files
for source (using wildcards or file1+file2+file3 format).
need the /b to tell it its binaryCode:copy /b 1.ac3+2.ac3 all.ac3 /b
can use wildcards as well e.g.
BUT using wildcards it will take the newest file as the first file part of the new file (found this out to late and had part 2 at the begining of a movieCode:copy /b *.ac3 all.ac3 /b
Split, join, create silence of an ac3 file
By phate89 in forum AudioReplies: 6Last Post: 16th Jul 2011, 13:34 -
join H.264 mp4 with a AC3/DTS/LPCM audio stream
By xrlem01 in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2009, 08:09 -
Can't join this movie that is split and already burned on dvd
By f-zer0 in forum EditingReplies: 3Last Post: 3rd Jan 2008, 21:21 -
Cucusoft DVD to iPOD - Join/Split Files
By technologistau in forum DVD RippingReplies: 1Last Post: 16th Sep 2007, 04:49 -
Re-join single DVD-9 film split onto two DVD-Rs
By denti alligator in forum DVD RippingReplies: 11Last Post: 24th May 2007, 20:47
