Hi all,
i have been asked by a friend to copy a few films to MPEG1 and using OSEx and ffempeg i've had good results.
the only problem i have is he needs them to be 320 by 240 pixels and the bit rate needs to be 1.3 M Bytes/sec. also the films need to be changed from NTSC to Pal.
I have got the pixel size of the film right but when i try and change bit rate it seems to have no effect on the encoded film. also when i change the film to Pal the audio isn't in sync with the video.
has anyone seen this problem before?? and does anyone know how to do it properly??
My process is rip to .vob using OSEx and then use the fast VCD preset changing the bit rate and the frame rate.
Thanks in advance.
Results 1 to 1 of 1
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 12:53 -
how do i know if Nero is changing my audio bit rate?
By uglijimus in forum Authoring (DVD)Replies: 5Last Post: 19th Nov 2008, 15:49 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 05:48 -
the right bit rate
By nojee in forum Video ConversionReplies: 5Last Post: 10th Nov 2007, 03:00 -
Changing Channel Effect
By MOVIEGEEK in forum EditingReplies: 1Last Post: 27th Jul 2007, 11:19
