    Sep 2003
    I have converted an avi file with Cuesoft AVI to VCD DVD SVCD 4.02 software to DVD files, a .m2v, a .mpa and .mpg file. The next step is to import them into IfoEdit to DVD author them. I keep getting an error of "Could not open for writing". Any ideas? I am using Win98SE. Are there any other programs I could try?
    Kal
  2. Member wulf109's Avatar
    Jul 2002
    you casn't open mpg files with IFOEDIT. you only need the m2v and mpa to create the DVD files.
    Sep 2003
    Yes, I know that you can only add the m2v and mpa files.
    Kal
