Hello,
I have an AVI that looks like it's supposed to be in 4:3 but maybe was captured from a 16:9 screen(?). Everything is stretched width-wise and the then there are black bars, like letterboxing, on top and bottom.
What I'm trying to do is "squish" the sides back in and basically resize to a 4:3 aspect ratio.
What I'm using is the 'Clip Frame' feature in TMPEnc which seems to be doing what I want.
My question is, does the Clip Frame feature truly just resize the aspect ratio or am I actually trimming part of the picture off the sides (pan & scan type thing)?
Secondly, is this the best way to handle a stretched video like this?
Thanks,
Tim
As long as you are just adjusting the height of the video and not the length then you are not cropping out anything on the sides and this method is one of the best ways to do what you are doing.
I guess that's what I'm trying to verify... that the Clip Frame function in TMPGEnc is only stretching the video, not cutting it.
Thanks for the response.
VHS Tapes - Fixing video that keeps "rolling"??
By RobV in forum RestorationReplies: 7Last Post: 22nd Nov 2010, 01:18 -
Help fixing "screaming" in audio.
By Thread7 in forum AudioReplies: 5Last Post: 26th Aug 2010, 18:26 -
[Suggestions?] Help "fixing" AVI files.
By Greg14 in forum Newbie / General discussionsReplies: 3Last Post: 20th Jun 2010, 02:15 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
"Fixing" TS streams
By n8gray in forum LinuxReplies: 2Last Post: 22nd Jul 2008, 02:26
