This one is driving me mad |
Why when importing a 1hour 3min episode from Sky, Via DVD-RTAV
(2.1GB on RAM Disc) do iI end up with a total of 5.49GB of clips
Timeline at bottom of Screen says 5.49 (5.11)GB / 1 Hour 3 Min 0 Sec
Mark
If you are using Ulead DVD MovieFactory 2, then please know that version 2.0 of the program does not support the AC-3 audio utilized by the majority of stand alone DVD player/recorders models.
I have a Toshiba D-R1:
http://www.tacp.toshiba.com/dvr/product.asp?model=D-R1
When I import video from the DVD_RTAV folder recorded by the Toshiba unit, I see the following properties:
NTSC drop frame (29.97 fps)
MPEG files
24 Bits, 720 x 480, 29.97 fps
Field Order B
(DVD-NTSC), 4 : 3
Video data rate: Constant (9000 kbps)
Audio data rate: 384 kbps
AC-3 Audio, 48 KHz, 2/0(L,R)
Therefore, I would recommend that you consider the upgrade to the new "Disc Creator" version 3.0 of Ulead DVD MovieFactory:
http://www.ulead.com/dmf/runme.htm
The "Disc Creator" version supports AC-3 sound.
Jerry Jones
http://www.jonesgroup.net
Originally Posted by Esprit Nutter
Ulead Movie Factory queries
By Mark Wynn in forum Authoring (DVD)Replies: 2Last Post: 11th Apr 2010, 20:42 -
alternative to ulead movie factory
By marlo in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2008, 03:48 -
Problems with Ulead Movie Factory
By merkuria_lyn in forum Authoring (DVD)Replies: 4Last Post: 25th Oct 2007, 13:12 -
Trouble with movie factory 6 pro Help!!
By blues100 in forum Capturing and VCRReplies: 3Last Post: 16th Oct 2007, 21:44 -
Ulead Movie Factory 6 plus
By ictaylor in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 02:20
