What is the best dvd burning software to create dvd`s , but i also want to be easy to use & be able to create good menus.
Results 1 to 30 of 47
burning and creating menu's would be different software, creating menu's would fall into the author dvd catagory, as far as menu's go..i would use dvd-lab. for burning, i use nero but heard good stuff about recordnow.
[EDIT] or actually for burning if u don't wanna spend money use imagetools to make an iso of the dvd and burn with dvddecrypter. -
tmpgenc dvd author is neat too. Its not freeware, obviously. But I made one dvd a week ago and it was a breeze. It can do nice custom menus, titles, and whatever else you want with it.
I have used Nero (5 & 6), Roxio 6, RecordNow, Ulead Movie Factory 2 SE and 1 or 2 other ones I could not remember off hand. I am sticking with Nero first. Roxio second.
Originally Posted by Mark Mc
makntraks -
I have used and think Adobe Encore is the best for authoring dvd's. Yes it's true it's not the most user freindly software but once you get the hang of it, it's the most flexible and customizable software I have ever used. Just make sure you apply the update as it fixes many bugs the software had originally.
Originally Posted by makntraks
Whats up with you???
Thanks for all the good suggestions i`ll try a few out & decide which one(s) to use. -
tmpgenc DVD Author will author and has a built in burning tool that works quite well.
This was such a n00b question, I had no choice but to yak...
makntraks
p.s
SEARCH is your friend... -
what guide is going to tell him what is the best burning software? none, so hes asking questions from experienced people about the pros and cons of the various burners. chill out
TMPGEnc DVD Author for menu creation and burning all in one.
IMO Nero is the best straight burning application hands down and by a country mile.If in doubt, Google it. -
Here's the way things usually go around here....
Noob buys a PC or some hardware like a burner, sets everything up, installs his software and loads up his video files, puts a DVD blank into his drive and presses the big "make DVD" button and ends up with shitty results.
Noob discovers this site. Noob joins the forum and makes a post just like you did here that we've all seen a million times. Noob then gets the following standard responses....
Noob is told to read the guides provided to the left.
Noob usually gets an answer to a question from another forum member and doesn't have to read the guide to get his answer.
That's all well and good, because that's what forums are here for...promoting the free exchange of information.
This is what usually happens next....
Noob that went and read some guides to find the answer to his problem usually finds it and discovers the wealth of info that a lot of people here have put a great deal of time and effort into, and continues to read and learn, and is usually not heard from untill he really gets stuck on something and can't find his answer by searching the site.
Noob that posted a question and got a quick response that solved his problem without having to read through any of the guides is usually back right away with a littany of noob questions he expects to be answered because he's stuck again at the next step of a multi-step process involved with creating a DVD that he was unaware of.
This is also fine, because again, that's why forums like this exist - to encourage the free & open exchange of information & ideas. It just gets to some people, seeing the same questions asked over and over and over.
That's why you had to wait 24 hours after you registered before you could post here."There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
TMPGenc DVD Author is for beginners.
It is very limited.
No audio or motion menus.
In other words Junk!!!!
DVD Architect all the way -
Yes and this is a newbie area.............so what is the beef???
Originally Posted by richdvd"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
Apparently you do not.
Like you.
Being the better man here, I'm walking away from this."There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
I especially like the way it labels every disk "New" no matter what label you type in. I haven't found any other software that's so efficient in ignoring what you tell it to do. -
Originally Posted by BobKIf in doubt, Google it.
> I especially like the way NOOBS like you
Look to the left:
"BobK
jimmalenko
A Jackass
Excuse my newness. At least you picked the correct nickname there. -
I personally have a liking for the way a lot of stuff is done to the source material you feed Nero, without Nero telling you anything about what it's up to, in its eternal wisdom!
/Mats
The best DVD burning software
By tarzan54 in forum DVD RippingReplies: 22Last Post: 1st May 2012, 05:11 -
By ingeborgdot in forum DVD RippingReplies: 6Last Post: 17th Sep 2011, 14:10 -
Need Quality DVD Burning Software?
By BassJunkie in forum DVD RippingReplies: 2Last Post: 7th Jul 2009, 10:11 -
Looking for DVD Burning Software!
By mats.hogberg in forum DVD RippingReplies: 1Last Post: 29th Nov 2007, 09:52 -
Best DVD Burning Software for flagging 16:9?
By markannab in forum Authoring (DVD)Replies: 17Last Post: 4th Jun 2007, 13:09
