  1. Guest
    I have numerous .AVI and .MPG files that I downloaded and would like to burn onto VCDs. After downloading and installing this program I have encoded several files, a few before reading the directions fully, and a few after reading the web manual regarding "final cut pro to VCD conversion". After following the directions on that, including deselecting "altivec" (I'm on a G3 mac) , I still don't see the .bin or .cue files. I get the audio, video, and .m1v files, but nothing else. Is there something I'm missing, is this a common problem? Or will just those 3 files suffice in making a Vcd?
    As a side note, has anyone combined the use of this program with VCD builder??
    Thanks a bunch for any help on this topic,
    Brian
  2. Check if there were spaces in your file paths.
  3. Guest
    There were spaces in my file paths, I'll try removing those and see how that goes. Thank you for the help
