hi,need help please
authoring a home movie in MF2 from dvd-recorder using edit disk function.
added menu & menu background music etc, this works fine but the resulting dvd has no audio from the actual video footage.i've tried lpcm & mpeg audio settings & niether work.this has only started happening after i installed MF3 then uninstalled it 'cos it kept crashing at the end so then i re-installed MF2 & this has happend.i'm in the middle of a project & would realy appreciate any advise anyone can give.
thanks
If you are using Ulead DVD MovieFactory 2, then please know that version 2.0 of the program does not support the AC-3 audio utilized by the majority of stand alone DVD player/recorders models.
I have a Toshiba D-R1:
http://www.tacp.toshiba.com/dvr/product.asp?model=D-R1
When I import video from the DVD_RTAV folder recorded by the Toshiba unit, I see the following properties:
NTSC drop frame (29.97 fps)
MPEG files
24 Bits, 720 x 480, 29.97 fps
Field Order B
(DVD-NTSC), 4 : 3
Video data rate: Constant (9000 kbps)
Audio data rate: 384 kbps
AC-3 Audio, 48 KHz, 2/0(L,R)
Therefore, I would recommend that you consider the upgrade to the new "Disc Creator" version 3.0 of Ulead DVD MovieFactory:
http://www.ulead.com/dmf/runme.htm
The "Disc Creator" version supports AC-3 sound.
Also, the FREE trial version does not support AC-3 sound.
Jerry Jones
http://www.jonesgroup.net
Originally Posted by tonx
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 21:58 -
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 12:25 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 09:02 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 02:19
