Hi Folks,
I am trying to design a menu with DVD-lab 1.3 and Photoshop 5.0.
Does anyone know how I can take a .psd pic and put it in the menu so that it just shows the text and not the nasty square background of the pic.
I thought I had done it by using photoshops magic wand to select the text that I wanted from the pic and moved it to a newly opened .psd pic (with a transparent background, Then I sprayed the new pic so that what I thought I had was.... a pic of the text I wanted and no background. I then saved it (as .psd) and used it on my menu. It looked great, just what I wanted but when I compiled, and burnt it (with dummy movies to check how the menus would look)....the image was not there.
maybe I put 2+2 together and got...5 (or 42 if your a Douglas Adam's fan), anywayz, if anyone can explain how to do this properly I would be really grateful.
Thx![]()
:) "Janey is m' Sunshine" :)
You might have better luck checking message boards over at:
http://www.mmbforums.com/
Question on DAR and best image size for a pal movie menu background
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 12th Mar 2011, 10:42 -
PowerDVD 10 - Blu-ray sound OK, menu navigation OK but no image
By rilopes in forum Software PlayingReplies: 4Last Post: 10th Aug 2010, 10:16 -
DVD Menu Image Buttons With Video Background
By sk8_aholic in forum Authoring (DVD)Replies: 3Last Post: 19th Nov 2008, 23:01 -
create a dvd menu from iso image
By DSLGuy in forum Authoring (DVD)Replies: 3Last Post: 19th May 2008, 09:30 -
Menu with image buttons
By lex1972 in forum Authoring (DVD)Replies: 5Last Post: 24th Nov 2007, 07:02
