Hi, i converted an svcd to dvd using Tmpg. Now i want to author the resulting .mpg file, which i have just made, and burn it to dvd. However, when i use tmpgenc to author the file, i test it first on my computer using power dvd, and every time i check the film goes progressively out of sync. I hae tried with out any chapters etc, and for some reason i still have the same problem??
Can anyone please point me in the right direction or give me any advice as to how i can resolve this.
The svcd, initially was not out of sync, neither is the converted file.
Thanks and any help is greatly appreciated
Use r/w media - burn and check results on set top. If audio sync still gradually goes out, dump entire project and look for a good replacement source file. Fixing that type of sync is extremely difficult.
Always check helpfiles/instructions before leaping... -
...if it's not that simple as that you're changing the frame rate when going from SVCD to DVD? Don't. Nothing but trouble down that path.
For simple SVCD to DVD transition, try SVCD2DVDMPG.
/Mats -
cool, thanks for the help guys.
I'm starting from scratch again, re-encoding the original file etc.
will let u know how it goes
thanks again
Need help with sync problems during processing
By Jon.G in forum Authoring (DVD)Replies: 23Last Post: 6th May 2011, 04:14 -
Audio Sync Problems
By eon_designs in forum Blu-ray RippingReplies: 2Last Post: 8th Dec 2009, 09:49 -
problems with sync
By joachimfreitag in forum MacReplies: 5Last Post: 10th Sep 2009, 15:00 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 18:37 -
Time sync problems.
By Poppa_Meth in forum ComputerReplies: 9Last Post: 1st Sep 2007, 00:30
