hello there,
i'm using dvd2svcd so as to convert a dvd documentary into svcd. i have read the three guides here at www.dvdrhelp.com concerning all the settings. i've even tried using avysinth 2.08 just in case 2.52 is buggy. i always get the same error:
mux start time is greater than the total time 0 seconds
sound is converted .ac3 > .mp2 without problems.
i'm using tmpgenc and i have realized the encoding time takes less than five seconds! which is just impossible for a 40minute documentary to be encoded. maybe that's the reason why i get that error since the resulting .mpg file created takes 0 bytes of my hard disk.
i have not been able to solve it on my own. please, give me a hand.
i have attached the log file so that you can have a look at it if you feel like it.
thanks a lot in advance,
sunmanking
WNASPI32.DLL 4.5.7.1008
- 07/03/2004 13:03:54
- DVD to SVCD Conversion
- DVD2SVCD ver. 1.2.1 build 3
Initializing
- E:\egipto_doc\VIDEO_TS\VTS_01_0.IFO
- E:\egipto_doc\VIDEO_TS\VTS_01_1.vob
- E:\egipto_doc\VIDEO_TS\VTS_01_2.vob
Initializing finished.
- 07/03/2004 13:03:57
- Analyzing subtitles
Subtitle found: StreamID: 0x20 Language: English
Executing subtitle selection/verification.
Subtitle selection/verification accepted.
1 subtitle streams selected.
Saving Subtitles ini file
- 07/03/2004 13:04:07
- DVD2AVI
Creating DVD2AVI INI file:
- C:\Archivos de programa\DVD2SVCD\DVD2AVI\DVD2AVI.INI
Variable settings:
iDCT_Algorithm: 32-bit SSE MMX
Executing DVD2AVI.
Executing DVD2AVI. Commandline:
"C:\Archivos de programa\DVD2SVCD\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -EXIT -OF=[E:\egiptosvcd\DVD2AVI_Project_file] -IF=[E:\egipto_doc\VIDEO_TS\VTS_01_1.vob,E:\egipto_doc\ VIDEO_TS\VTS_01_2.vob]
Framerate: 25000
DVD2AVI processing done.
- 07/03/2004 13:06:12
- Free on drive C: 3245.38 mb
- Free on drive E: 14055.99 mb
- Extracting the subtitles.
Subtitle extraction finished. Extracted these subtitles:
SVCD Stream no: 1 Language: English Num. of subs: 0
- 07/03/2004 13:08:20
- Free on drive C: 3244.64 mb
- Free on drive E: 14056.05 mb
- AUDIO Extraction
Found AC3 stream id: 0x80
Filename: E:\egiptosvcd\Extracted_audio_1.ac3
Found AC3 stream id: 0x81
Filename: E:\egiptosvcd\Extracted_audio_2.ac3
Audio1 delay: -80 ms
Audio2 delay: -80 ms
Framerate: 25000
Audio extraction finished.
- 07/03/2004 13:12:05
- Free on drive C: 3241.45 mb
- Free on drive E: 13839.37 mb
- AUDIO conversion
Encoding Audio. Filename: E:\egiptosvcd\Extracted_audio_1.ac3
Executing BeSweet. Commandline:
"C:\Archivos de programa\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "E:\egiptosvcd\Extracted_audio_1.ac3" -output "E:\EGIPTO~1\Encoded_audio_1.mp2" -logfile "E:\EGIPTO~1\Encoded_audio_1.log" ) -azid( -L -3db -C 0db -S 0db -c normal -s surround -g max ) -ota( -d -80 ) -2lame( -e -b 128 -m s )
Audio conversion of E:\egiptosvcd\Extracted_audio_1.ac3 finished.
Encoding Audio. Filename: E:\egiptosvcd\Extracted_audio_2.ac3
"C:\Archivos de programa\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "E:\egiptosvcd\Extracted_audio_2.ac3" -output "E:\EGIPTO~1\Encoded_audio_2.mp2" -logfile "E:\EGIPTO~1\Encoded_audio_2.log" ) -azid( -L -3db -C 0db -S 0db -c normal -s surround -g max ) -ota( -d -80 ) -2lame( -e -b 128 -m s )
Audio conversion of E:\egiptosvcd\Extracted_audio_2.ac3 finished.
Audio conversion finished.
- 07/03/2004 13:36:16
- Free on drive C: 3236.50 mb
- Free on drive E: 13767.19 mb
- Video Encoding using TMPGEnc
- Encoding Test Clip C:\Archivos de programa\DVD2SVCD\Movie\AviSynth_Script_file_CQ_TE ST.avs
Executing TMPGEnc. Commandline:
"C:\video\TMPGEnc Plus-2.521.58.169\TMPGEnc.exe" "E:\egiptosvcd\TMPGEnc_Project_file.tpr" /Encode /Close
Video Encoding finished.
Wanted: 680478010 (664529kb)
Predicted: 356155 (348kb) Using CQ Value: 80.00
Calculated next CQ Value: 100.00
Predicted: 625697 (611kb) Using CQ Value: 100.00
Calculated final CQ Value: 100.00
- Encoding C:\Archivos de programa\DVD2SVCD\Movie\AviSynth_Script_file.avs
StreamSectors: 771537788
AudioSectors: 76863976
VideoPAPO: 10760868
ScanOffsetBytes: 53209
SeqAligningBytes: 3381721
DVDBytes: 0
VideoEndHeader: 4
SubtitleSectors: 0
EmptySectors: 238.00
PictureSectors: 0.00
PureMPEGStream: 680478009.90
Seconds: 2369.84
CalcMPEGStream: 680478009.90
Frames: 59121
CDSize: 740.00
Number of CDs: 1
Cut point 735.00
Aspect Ratio: 4:3 (No borders, encoded as 4:3)
---AVS Begin---
LoadPlugin("C:\ARCHIV~1\DVD2SVCD\AVISYN~1\Mpeg2dec \mpeg2dec.dll")
mpeg2source("E:\EGIPTO~1\DVD2AV~1.D2V")
BicubicResize(480,576,0.0,0.6)
ConvertToRGB()
----AVS End----
- 07/03/2004 13:36:55
- Free on drive C: 3236.42 mb
- Free on drive E: 13767.15 mb
- Converting Pictures from ES to PS
Saving bbMPEG settings: C:\Archivos de programa\DVD2SVCD\bbMPEG\default.ini
- 07/03/2004 13:36:58
- Free on drive C: 3236.41 mb
- 07/03/2004 13:37:01
- 07/03/2004 13:37:03
- Multiplexing and cutting
Offset in Seconds: 2
Executing bbMPEG.
Variable Settings:
Movie offset: 2 seconds
Cut point: 735 mb
Executing RunbbMPEG. Commandline:
"C:\Archivos de programa\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "E:\egiptosvcd\bbMPEG_Muxed_File.mpg"
bbMPEG failed. Exitcode: 3221225477
