Any have a suggestion for a lapel mic I can use while talking into my JVC? In particular, I'm looking form something that isn't wireless....just has to have a 20' cord.
Results 1 to 9 of 9
I just checked out Radio Shack and they have a lapel mic, but the cord is only 3.5' long...will a 12' extension increase noise too much?
Best is an electret with a battery. You should be able to run an extension cable of 10-15 feet an not get any hum or noise. Might want to try the combo out in the store if they will let you to make sure.
Will this one do the trick?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3802134442&category=3319&sspagename...EBWA%3AIT&rd=1 -
Yes, that would probably work OK. However, Sony sell that for $14.95US at the 'Sony store', so the price isn't that good.
Using wireless mic with shotgun mic on Canon HF G10
By jimleben in forum AudioReplies: 5Last Post: 23rd Jan 2012, 21:11 -
LG HT 305SU (MIC IN / MIC OUT Problem)
By iamjamal in forum DVD & Blu-ray PlayersReplies: 0Last Post: 25th May 2011, 17:38 -
external mic
By Christin in forum AudioReplies: 2Last Post: 23rd Feb 2011, 14:16 -
Best quality wireless lapel microphone
By Habby in forum AudioReplies: 0Last Post: 25th Jul 2010, 21:54 -
SONY ECM-CS10 Uni-directional Stereo Lapel Microphone
By BlueDevilfish in forum AudioReplies: 0Last Post: 19th Apr 2009, 00:10
