I'm brand new to this stuff, so please type slowly for me.![]()
I have a Canon Optura 200MC, and a a Radeon 8500 video card running on Win2000. (full computer specs in profile)
I understand that my video card doesn't capture video, but I also have 2 open Firewire ports. The software/manual that came with my camcorder says I can only capture video through the Firewire port if I'm running WinXP, which I'm not willing to do.
Am I S.O.L. without upgrading my video card or switching to XP, or is there something else I can do with my current system?
Thanks.
Hi Drooling Dog,
I run Win2K Pro as an O/S and capture via Firewire from my miniDV cam perfectly OK.
I'd say, give it a go and see how it looks. Freeware capture tools: DVIO, WinDV.
Read the "Sticky" titled "Why does your system drop frames?" in the Capturing forum to make sure you can eliminate any problems with dropped frames so that, if you do have a problem (of any kind), you've already ruled out a lot of possible causes.
If you capture to DV AVI (type 2), you're looking at around 13Gb per hour of footage. Then use GSpot or AVICodec to get info on your AVI file.
Basic info:
PAL: 25fps, 720 x 576 picture size
NTSC: 29.97fps, 720 x 480 picture size
Hope that helps. Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Yeah, you do need to use firewire to transfer your DV video from the camera to the computer, but that should really be possible with any Windows OS from 98SE on up. I don't think any extra software from Canon is needed for a simple transfer of video. The firewire and camera drivers should be included with Windows. Connect everything up per the manual and see if WinDV can see the camera.
I think that would be the limitation of the specific software that came with your cam. As pointed by Daamon and Beavis try to use other capturing softwares, there should not be any problem.Originally Posted by Drooling Dog
SaurabhHard work never killed anybody,
But why take the RISK
Which camcorder (newbie question)
By CliveJ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 19th Aug 2011, 13:36 -
Should I Get An HD Camcorder? (Newbie)
By davebo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 18Last Post: 21st Jan 2011, 04:48 -
Newbie Needs Help: Searching for a camcorder
By RHMaxwell in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 11th Jan 2011, 10:32 -
Newbie here, which camcorder should i get?
By defectivelasagna in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 16th Aug 2009, 12:52 -
Newbie questions about HD camcorder etc!
By n33712 in forum Newbie / General discussionsReplies: 10Last Post: 4th Mar 2009, 15:16
