I have been trying to create some menus for some mpegs and avi shows. When I try to save the project it says "Project Initialize Failure". If I skip saving the project and try to make a ISO image instead, it just makes about 9% progress then freezes.
All I can think of is that the AVI files are messing something up.
Is there something I need to do or change so that I can save the project and make an ISO image from it?
If everything is infinite then nothing is definite.
What are the precise video/audio properties of the MPEGs?
Likewise, what are the precise video/audio properties of the .AVI files?
If you're using "videos downloaded from the internet" or "videos ripped from a DVD," then those types of source files can throw a monkey wrench into the MPEG conversion engines of several of today's DVD authoring applications, which have generally been designed with DV .avi source files in mind.
Jerry Jones
http://www.jonesgroup.net
Originally Posted by Thommers
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 06:44 -
Convert my dvd's to Avi
By drgt in forum Newbie / General discussionsReplies: 52Last Post: 3rd Dec 2010, 05:28 -
AVI and convert to DVD
By Jomapil in forum Newbie / General discussionsReplies: 6Last Post: 12th Mar 2008, 14:33 -
Convert DVD to DV AVI
By bgmagic in forum DVD RippingReplies: 14Last Post: 4th Feb 2008, 13:55 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
