I was wondering if anybody can tel me how to change the first play action in DVDLab 1.3?
Much Appreciated
Probably the easiest way would be to go into CONNECTIONS view, click the connections button, then link the FIRST PLAY icon to what you want to play first. Don't forget to link the end of the item you want to play first to the menu or movie next in sequence.
Thank you for the help. I figure out how to do it not long after my post. got caught up doing my dvd that i forgot to post back and say i answered my own question.
I appreciate the Help
syoung
FFmpeg - Change encoding rates while in-action
By ronts in forum Video Streaming DownloadingReplies: 5Last Post: 12th Aug 2011, 00:16 -
DVDLab Pro problem, menu background colors change when rendered.
By PSPGamer in forum DVD RippingReplies: 19Last Post: 2nd Mar 2011, 20:42 -
:?: half-speed play with no audio pitch change?
By gregconquest in forum Software PlayingReplies: 8Last Post: 10th May 2008, 22:21 -
First Play problem in DVDLab PRO
By grzegorz in forum Authoring (DVD)Replies: 5Last Post: 11th Apr 2008, 04:43 -
DVDLab Pro: non-working links and duplicating item in play list
By daamon in forum Authoring (DVD)Replies: 6Last Post: 25th Jul 2007, 06:12
