  1. I have 30 non stop tracks which I rip from a friend's cd. Now I want to burn it on a cd-r (audio). When I select the gap as 0 secs, it still has a little stop time in between tracks. How to burn as the original non-stop cd without any glitches?
    thanks
  2. The CD has to be burned as disk-at-once for this to work. I'm not sure if this works for music CDs, or only VCDs...
  3. It works for audio CDs only (and not for VCDs).
    However, if you ripped the audio to 30 separate audio files, it is unlikely that even burning it as DAO you will get flawless continuous tracks...
    The next time you copy an audio CD with continuous tracks, you will have to copy the disc as an image and then burn the image. You can do this with most CD burning proggies.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  4. hi thanks for the info...but I do not understand the part where I have to copy it and burn it as image...can explain it more simpler way...
    Anyway...I tried again burning yesterday using nero..I even tick the option to discard empty spaces at the end of *.cda
    But still when I play it, it has this minor gaps inbetween tracks.
    If you notice when u play original non-stop cd, before the next track comes in and while the current track is playing, the display will show "-1"sec and than the track will play without any gaps at all. How can I do this with roxio or nero? Or is there any other software which can help me to do this?
    If there is no software which can do this, suppose I take the back the original cd from my friend...how do I copy it then? I only have one cd burner in my comp, and when I use the function "cd copy" it always give me an error. Can help to explain the steps to copy in either nero or roxio?
    HaMMeR
