I'm not sure if this is the correct forum for this tpoic so forgive my newbie ignorance if not.
I have 2 questions.
The first one is, i have several burning softwares and today i tried to use my Intervideo DVD Copy. I re-authored a dvd tonight with dvd shrink and was able to burn it ok with clone dvd (trial so far :P ). Anywhooo I opend up Intervideo dvd copy to see how well it would handle the re authored files for a cd-r using Divix(r) and it tells me the Divix(r) encoder is not installed. Is there somewhere i can get this from or is it something you have to buy as a plug in.
The second question is kind of the same.
I'm using cyberlink power dvd to watch on my pc and every time i load a movie it gives me a message as follows:
The found divix direct show decoder (divx_c32.ax) may be incompatible with current operating system. Please try to install version 3.11 or 4.0+
I have no idea what this means or how to get it
Thanks for helpin a noob
Results 1 to 1 of 1
Question about x264's interlaced encoder vs. progressive
By Asterra in forum Video ConversionReplies: 4Last Post: 9th Jul 2011, 17:13 -
Windows Media Encoder Question
By Gabaldad in forum Capturing and VCRReplies: 5Last Post: 24th Sep 2009, 17:48 -
avstodvd encoder question
By marioval in forum Authoring (DVD)Replies: 1Last Post: 19th Jun 2008, 03:33 -
MainConcept MPEG Encoder 1.5 question
By hanugro in forum Video ConversionReplies: 6Last Post: 21st Feb 2008, 21:27 -
Question: Freeware AVI To MPEG-2 Batch Encoder?
By Jeremy of Many in forum Video ConversionReplies: 36Last Post: 27th Jun 2007, 19:25
