Hi
I've seen the many posts here before regarding the pioneer patch issues. I donated to the software and started putting my SVCD's on DVD.
I have a problem with the pan and scan option. Basically I ripped 3 svcd's to mpeg with the pan and scan option set, then I let SVCD2DVD do its stuff. The problem was that I selected the wrong hard disk and the one I selected didn't have enough space so when it came to creating the TS_VIDEO folder the program locked up due to lack of space for the VOB'S so I had start again.
I didn't want to go through the motion of ripping the Mpeg's from the Bin files so I placed the DVD.mpeg files into a folder and set SVCD2DVD to work on them. The log checked the files and said all were ok as they had NAV packs and would leave it alone. The resulting Vob files when played on my Pioneer had the same problems as everyone else with the screen being to the left.
Can I actually just work straight from the DVD.mpeg files or do I have to set SVCD2DVD going again from the ripping of the bin files?
Cheers
Add: I should add that if i do a normal rip and make sure there is enough space then it works fine on my player, I just don't fancy going through the SDE placing with 3 bin files again and wondered if i could work from the DVD.mpeg files.
Results 1 to 1 of 1
Pioneer DVR-530H Question (Please help)
By Corey_Futurama in forum DVD & Blu-ray RecordersReplies: 7Last Post: 10th Jul 2010, 08:28 -
Question about the Pioneer DVR-650H-S
By jh76 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 7th Jul 2008, 22:53 -
Pioneer DVR-531H-S Question
By mattg568 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 12th Jun 2008, 05:48 -
Pioneer 112D to 112L question
By Trailryder in forum DVD & Blu-ray WritersReplies: 8Last Post: 20th Aug 2007, 13:26 -
Pioneer DVR-710 Question
By hollywoodfussell in forum DVD & Blu-ray WritersReplies: 12Last Post: 20th Aug 2007, 13:25
